when i start the motor it always takes 2 to 3 key turns to get it to fire? i checked the iac and found a lot of carbon build up and cleaned it but still happening? there are no codes... what else should i check? its not the fuel pump as it it new, not the pcm as i have swapped it out with no change, and not the injectors as they have been swapped too... could it be a bad iac as it runs fine other than starting issue....
thank you in advance for you help
