hdnseek
So about a month ago I went out and logged some 0-60 times on my ls1m logger and was having trouble getting it under 7 seconds. Since then I have capped the boost bypass solenoid, replaced the broken front sway bar on both ends with a 34 mm solid Dorman with all moog poly bushings. I also flipped my motor mounts. It is helping keep the car on the ground, but the capped boost bypass solenoid keeps boost even when no traction so I'm getting launching down. Other mods are 255 lph fp, u bend delete, resonator delete. Tonight was the first night I launched to 60 in under 6 at 5.94 seconds. Stock specs say 0-60 in 6.5- 6.7 but want to know what you guys are getting and what mods you have. Mine pretty much stock but let me hear your Input so I can relate if I have a decent time or not..
Sent from my HTC One mini using Tapatalk
