Compression test procedure?
Elite6
Been searching around with some luck, i want to confirm if this procedure is correct or not
1. Remove electrical connector from the coil pack area - I think its called the ICM connector?
2. Disconnect fuel pump fuse
3. Block TB open
4. Do one cylinder at a time
5. Other cylinders have plugs installed & wires connected
6. Crank over car 5 times per cylinder
Is that correct?
