    TIPS:
Complete transmission rebuild kit GM 4T65E
pianobomber
To the best of my ability, her are the details of this kit and what is included:
***4T65E Transmission Overhaul Rebuild Kit w/Filter
____Transtec overhaul set, factory replacement Borg Warner (not Alto) complete high energy friction set, filter, bonded pistons, forward band, front seal and axle seals.
***4T65E Transmission Solenoid Kit
____Two (2) New Shift Solenoids
____One (1) New EPC Solenoid
____One (1) New TCC (Lockup) Solenoid
____One (1) New Manifold Pressure Switch
***Boost valve & sleeve 4T65E 1997-UP SONNAX 84754-30K
***4T65E 4th Gear Clutch Hub Hardened
I had originally intended to rebuild my 97 GTP transmission, but that will not be happening. In actuality, I know little about the various parts that are involved with a transmission, but I can tell you this kit includes various gaskets and seals, and perhaps the picture will tell the whole story. I apologize, if you ask too many detailed questions, I may not be able to answer them.
Otherwise, for $250 (shipping included), you can have everything. I prefer PayPal, but can also accept a USPS Money Order if you insist upon it.
Hit me up with a PM, and I will respond. :-)
hmmm i got a nice 4340 input and hardened pump shaft forsale that would go good with this..........
good luck with sale OP!
what all else with this kit and your input and pump shaft would be necessary for a decently built trans to withstand lets say 325 to the wheels
id reccomend just the rebuilt kit input shaft pump shaft 7/8s chain setup and valve body from triple edge. that would basically be a duplicate of the trans that is in my bronzemist e85 s1x cam setup that made 330whp and 400wtq.
upgraded valve body makes a huge difference in how the car drives and behaves along with the 7/8s chain would be solid for a supercharged car.
