Common part numbers: Pulleys, Goops and Gaskets
BillBoost37
Please add on if you have more stuff. It's always good to give folks more info.
Pullies
Series I
Tried to find info on Series I and only came up with one pulley used twice.
Part#....OD......ID.........Info
89007...76mm...17mm...23mm flat pulley
Series II
L36
Pos...Part#....OD.......ID.......Wide.....Info
3......89007...76mm...17mm...31mm...flat
L67
9......89006...90mm...17mm...30mm...flat
8......89051...76mm...17mm...23mm...6 rib with flange
L67 with 8 Rib SC Pullies
8......89053...76mm...17mm...NA........8 Grooves with flange (3")
8......89057...90mm...17mm...NA........8 Grooves with flangle (Optional 3.5")
3 SC..89016...74mm...17mm...37mm....flat (SC tensioner pulley)
9......89048...90mm...17mm...37mm....flat (Optional 3.5" for pos 3 if SC'd)
3......89007...76mm...17mm...31mm...flat (6 rib accessory belt tensioner pulley)
** All part numbers are from the Dayco.com website.
Gaskets/Parts
Series 2
Part # ............Name.................................................Rockauto
Fel Pro
MS98014T........Aluminum LIM gaskets..............................$51.79
70644..............Oil Filter Adapter Gasket............................$1.09
ES70599...........Fuel Injector O-rings (need 3)....................$1.91
VS50465R.........Valve Covers (L67) w/grommets................$40.79
VS50080R.........Valve Covers (L36) w/o grommets...............$9.38
ES72833...........Valve Cover grommets..............................$7.26
MS95744...........Plenum (SC to LIM) gasket w/rings (L67).....$8.43
MS95812...........Plenum (UIM to LIM) gasket (L36).............$32.99
61024..............Throttle Body gasket (L67)........................$3.52
61093..............Throttle Body gasket (L36)........................$3.72
35595..............Thermostat Housing gasket........................$1.00
35666..............Thermostat Seal (rubber)...........................$1.87
CS9917.............Lower Conv gasket set (96-99)................$30.79
Dorman
47065..............Coolant elbow.........................................$4.00
47065HP........Aluminum Coolant Elbow
47037...............Map/PCV Cap kit..................................$~10.00
Napa
660-1736..........Coolant elbow.........................................$?
GM Dealer
89017816 ..........L36 Lower intake gaskets........................ ~$50
89017825 ..........L67 Lower intake gaskets........................ ~$50
24505049..........Rear Int Coolant Cover....................~$8 (the lim coolant cover under TB)
89017274..........L36 map/cap kit................................~$20
12346004..........GM Pipe Sealant with PTFE...................... ~$10
12345982..........GM S/C Oil (M62 1, M90 need 2).................~$10
12584411..........Gen V M90 Aluminum gasket......................??
1052943...........Gasket Maker.(Charger snout to body seal)......??
16194007..........NA (L36/L26) MAP sensor accoridan seal
Parts Store
Permatex Ultra Copper RTV - works for every fluid in our cars except supercharger
Permatex High Temp RTV Silicone Gasket Maker 26B - Used for sealing paper gasket on intercooler.
Shorter Dog Bones: Anchor 2899 (Montana)
Oversized Radiator: Spectra CU1518 (95 Lumina 3.4L, need 95 GP lower hose)
Adding stuff
I'll add some Autozone part numbers I suppose cause I'm bored.....
Pullies
Series II
L67
Pos...Part#.........OD.............ID............Wide.........Info
7......34195.......................................................A/C bypass pulley
8......231086.......76.............17mm........12mm.......grooved pulley
3......231107.......76.............17mm........12mm.......smooth w/ no flange
9......231081.......90.............17mm.......12mm......3.5" smooth
4......300-130......5-25/32 in..................1 5/32 in...usually special order
* ID and Wide are bearing sizes according to Autozone computer.....
Gaskets
Autozone carries felpro gaskets so the felpro numbers come up in the computers......
Other Crap
Item name.........Part#......Warrenty...Info
motor mount......15309......LLT..........Torque strut (dogbone) to radiator support *hint: search the forum on how to "flip" these when installing them.
motor mount......2866........LLT..........Torque strut mount AKA "dogbone" (standard length)
motor mount......2899........LLT..........Torque strut mount AKA "dogbone" (99 pontiac montana 3.4, said to be shorter)
motor mount......2796........LLT..........Other motor mount
front hub...........513121....1YR..........Timken front bearing/hub assembly
front hub...........DL513121.1YR..........Duralast front bearing/hub assembly
rear hub............512237....1YR..........Timken rear bearing/hub assembly
rear hub............DL512150.1YR..........Duralast rear bearing/hub assembly
cv shaft............9471N......LLT..........New Duralast Gold drivers side (usually special order)(both GTP and Non-GTP)
cv shaft............n/a..........n/a..........New Duralast Gold passenger side (NOT AVAILABLE)
9471........LLT..........Reman Duralast drivers side(both GTP and Non-GTP)
cv shaft............9472........LLT..........Reman Duralast passenger side(GTP model with 4t65-e HD tranny)
9468........LLT..........Reman Duralast passender side(NON-GTP models with standard 4t65e tranny)
fuel filter...........
FF4508...................Located on sales floor at most Autozones, you can go get this one yourself!
oil filter.............3387.......................Standard filter in STP and Fram
oil filter.............3331.......................Standard filter in Bosch
M1-101...................Standard filter in Mobil
HP-1001..................Standard filter in K&N
oil filter.............PF47.......................Standard filter in AC Delco
oil filter.............3980.......................Extra long filter in STP and Fram
oil filter.............3430.......................Extra long filter in Bosch
oil filter.............M1-201....................Extra long filter in Mobil
oil filter.............HP-2001...................Extra long filter in K&N
oil filter.............PF-52......................Extra long filter in AC Delco
*(can ask for oil filter for a 97 s10 2wd 4.3L if you have problems locating the longer filter)(I use the longer filter on my 97 GTP with no problems, usually cost the same for more filtering material so why not?)
air filter.............8136......................Blue 3inch Spectre open cone filter
air filter.............8132......................Red 3inch Spectre open cone filter
air filter.............8138......................Chrome 3inch Spectre open cone filter
air filter.............888038...................HUGE 3.5/4 inch washable/reusable Spectre filter (like 10 inches tall and 6 inches around)
*If mounting right to TB, you will need to make a hole in the rubber of the filter for the IAT sensor......
Oversized Radiator...........................Same numbers as bill's post
Lower Rad. Hose..D72038..................95 GP 3.1L lower hose
Lower Rad. Hose..B71778..................95 GP 3.4L lower hose(think this one is right, maybe Bill can chime in and confirm he meant 95 GP 3.4L lower hose)
LINK TO ALL THE LOAN-A-TOOLS>>>>>http://www.autozone.com/autozone/ac...-Equipment/Loan-a-Tools/_/N-26vd?target=shelf (hope its ok to post the link?)
(yes the W-Body specific strut spring compressor tool is in there under part# 27034)
(the 27032 flange puller attachment and 27033 slide hammer can help get those stubborn bearing/hub assemblies out, or just hit them with a hammer. lol)
For some reason, we don't have the fuel line disconnect tool (for the lines that go over the supercharger) in loan a tool but the part number you should need is 25043, which you have to buy.
*LLT=Limited Lifetime Warranty, 1YR=1 Year Warranty
*No Prices because prices will vary between Autozone stores.....
If you guys find this useless, then ill leave it at this, if you guys think its helpful, let me know and Ill post more.....also if you see any errors or part numbers you would like to see, please let me know!
I am NOT doing this to try and promote Autozone (yes i work there). I am simply trying to use my position as an employee to provide info for fellow GP'ers....
edit:not sure why there are extra spaces here and there, i tried to fix them but it wouldn't let me.....
Dayco 89051 - Ribbed idler pulley/supercharger - Doesn't properly fit without modification
This pulley is metal, and the OEM bolt/washer rubs the front and prevents it from turning.
Going to try Gates 38009 next. It's a plastic unit that looks like the stock one.
