I have the KYB AGX, I'm only running what I am running because of the drop I'm on (around 3.5-4") You will want to find the magic spring rate and only drop 1.5" tops, the more you keep those LCA's parallel with the ground the better. That is why shortening your AGX's rod may not be a bad idea either, since your not after a big drop, then a shortened rod won't hurt you. Other things you can do are when you go for an alignment you want to zero out the toe (I think GPs run 0 toe out) or go 0.5* positive. Going much more then that you will just burn tires (at 0.5* you will burn tires a little faster than normal but its livable) and your turn in will be like night and day.
As far as ZZP spring rates, I think they run on the light side of things to keep the stock feel to the car, I think 175# and 250# (front/rear respectively). These springs are cheap on Summit, I think $20 a spring, so you may have to try one set of springs for a season, see how it feels and then change to another spring another season, you have to find what is best for you and your driving style. But I'd keep it between 200-300#'s.
Other things I have considered in the past were Sub Frame Connectors (google it), alot of guys go custom here. I'd tie the front subframe to the rear trailing if I could (I think that would be the best route, but not 100% sure if it would be feasible). These will help stop body flex from corner to corner, which this car has....BAD.
Other options are Fender braces as well, which when making a sharp turn in, will keep the front pointed straight and where you turn. Since when they make a frame for a car, the passenger cell tends to be seperate from the engine bay compartment, so the firewall can be a weak point. This car doesn't exhibit it as bad as some cars I've had in the past, but it does have some weakness. These two mods can be done down the line once you dial in your suspension and you want to nickel and dime everything.
Waiting for Matt to chime in....
There was also talk of aluminum inserts for the subframe bushings at one time, but not sure what happened to that.
