Coilover Overhaul! Help NEEDED!
SKGrierson
A few years ago I purchased a set of the ZZP coilovers with the AGX Struts for my 2005 GP GT, and converted everything in the front suspension. I eventually moved for college and removed everything, but when I took them off some parts got damaged. The plastic threads were damaged in the process along with the actual collar of the coilover and the needle bearings that sat between the strut plate and the spring. I purchased the roller bearings once before, but forgot where i purchased them from and can't figure out for the life of me where I purchased them from online :th_scratchhead: SO, I just need the parts mentioned above which I will list below as well.
1. Threaded plastic sleeve
2. The set collar & set screw
3. The thrust bearing
Any help would be appreciated. Thanks!
EDIT: I FOUND AN OLD WRITE-UP WITH A LINKS THAT STILL WORK.
