gordster1122
I am looking at getting a code scanner that can read abs and here are my two choices what would be the better scanner??
Robot Check
Robot Check
Robot Check
Robot Check
if using the app i posted, you can clear history. then drive the car if the abs light comes back on, re scan. that new code will be the relevant issue.
most of the time if the issue has been fixed, the abs lights will go out on their own.
I am using the app you posted when I try to clear the codes they wont they keep coming back
ok, you have active codes then, google them and see what its for.
This is what comes up on the scanner and cant clear them
Yeah I amyou try hitting the trash can top right? been a while since ive used my app. but i know i cleared my regal and the tahoe.
