Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
Quicklynx
I have emissions check next week and I'm throwing this code. Do I need a whole new MAF or just the sensor?
Awhile back my car was riding real rough and it had a wild idle. I was throwing this code then. I unplugged the sensor way back when and haven't had a problem since running on the MAP.
Point is I won't pass the emissions check next week without getting this fixed.
I'm also throwing the Throttle Position Sensor code as well but that's because I was fooling with stuff. I'm thinking that was my fault but it still was registerring on my HPTuners even after I hooked it back up.
Any help is appreciated! Is there anyways I can prevent the car from throwing codes by using the HPTuners at least to get through my emissions? Thanks!
You may want to check the connection at the MAF sensor.. This code, P0102, is caused by an abnormally low reading from the sensor. The few times I have seen it, the wires were loose/damaged/etc (causing to the signal to drop to 0 when driving).. Or the sensor itself is failing.
Yea I inspected them and everything looks fine, but maybe its internal in there wires or sensor or something.
got my new maf in the car yesterday... ses light has gone off... now it better STAY off. gotta scan for thayt stupid p0102 code again when i can bring my car into class
