cockpit blower
Under the dash, passengers side.
You remove the fuzzy cover from under the dash, and if you look under the dash, you will see a round can hanging down thats about 4" or so wide. Thats the bottom of the fan motor housing exposed. There are three samll screws that hold it in, remove those, and it falls right out the bottom.
There are two wires that connect the fan to the rest of the car. I believe if it has never been replaced, there is a factory connection, if it has been replaced then there wont be unless somebody added it in.
Before you do anything, disconnect your battery (negative) cause the out side of the fan motor housing can spark and short things out if you get a wrench or ratchet in there wrong.
~F~
