Close to having everything for my top swap, can someone verify all this for me?
hockeybawler
Alright so I am getting close to having everything I need for my top swap, just wanted to take a few pics of everything I have and say what I think it is and what I think I still need and have you guys verify it for me so I can finally get this all installed.
Supercharger
MPS hub
Fuel rail
Supercharger gasket
LIM gaskets
Valve cover gaskets
Left? Head gasket
Harmonic balancer
Heads
Coil pack bracket?
Now if all of that is correct and you guys don't see anything that I have but missed then I believe all I need is:
Right? head gasket
Supercharger oil
MPS pulley
Pulley belt
Head bolts
Thread sealer
Rocker bolts
Tensioner
Idlers
Colder t-stat
Spark plugs
Lim
Does this all seem right or am I missing something? Thanks for all the help!!
you already have a lim...its on the supercharger already.
See that is what I thought to but the guy I bought it all from said it didn't come with the lim... Thanks for clearing that one up for me! And as for the idlers I have that on my list of parts I need and the tuned pcm is happening after I put it all in. I am getting it tuned at a local shop
Well that bracket is not the coil bracket. Its the drivers side dogbone bracket.
Those valve cover gaskets are crap.
Do you have the sc to lim bolts? Stand off for the lower sc belt idler w/bolts?
Injectors w/connectors?
Is your car an 04+? If not, you need an l67 fuel rail, not l32.
If newer than 05? Youre going to need another pcm to flash.
That's red painted brace isn't for your coil packs . That's the dog bone mount that mounts to the drivers side head
So am I missing one dogbone bracket or do I not even need that one?
I have the bolts from the sc to lim. I don't have the standoff, can you show me what that looks like?
I thought you didn't NEED the injectors but it was recommended?
I have a 04 so I am good on my fuel rail and pcm
you need the coil pack bracket because thats where one of the idlers and the tensioner mount.
No idea where to find pictures of the standoff, hopefully someone else will post some up.
Stockers might be good for 220 CHP or something in that region.
L32's will support a bunch more. Which you will probably flow enough air to make granted you're installing headers as well.
If not, I'd look into a 4.0/4.2 MPS.
Alright so I will also grab the connectors and injectors. Is the coil bracket the other dogbone mount I am missing? I am a little confused on that
Yea it's the mount on the passenger side of the engine it's the whole dealio . It's the dog bone mount / coil pack mount . It bolts on the passenger side front head then from there the supercharger tensioner bolts onto that and I believe an idler pulley as well
I don't have the best picture of it but ill try to search through my pictures and find one
Oh ok I see it now, thank you for the picture. I also looked at it on google to get another look at it. I appreciate all the help I am getting. Is there any way anyone can confirm that I have the left head gasket and not the right one?
I will figure it all out tomorrow when I get some free time. If anyone would like to help out and shed some light on whatever it is that he is talking about would be great!
