Climate Control Issue, please help!
Ok, I have a 97 GTP, its dark green, and has a black interior, god it gets so hot in there. I have recharged my A/C, and replaced the fuse for the high speed on the blower. It blows cold, but does not really cool the car. It seems to come out everywhere (the floor, the vents, and the defroster). I have an 8 month old, and I really cant drive it anywhere with her because after five minutes she is sweating really bad. Please help!!! What could it be?
Check the vaccum lines under the hood going around the engine bay on the passenger side i noticed this issue too and it was a broken line sitting by the alt. i taped mine up atm till i get a good connector seemed to fix
Thanks, will check and see what I come up with, I really hope its that simple! I only had one window that worked too, so I couldnt cruise with windows down, so I just took the window motor and regulator out lol, now I at least get a breeze!
I did the same as above, but mine was also broken in the wiring harness. I ended up replacing the line into the car, sliding a brake tubing line beside the transmission selector line, and cutting a slit in the lower firewall insulation/ rubber boot on the inside. (passangers side footwell, the filler panel will need to be removed via 3 plastic rivets.)
