climate control center issue
mofford12
okay so my issue right now is my blower motor is either bad or isnt engaging because of another issue... my rear defroster light doesnt come on and i have switched out the whole climate control piece that goes under the radio.. now could those issuse be related or no? also i checked fuses there good
Have you checked the underhood fuses as well? Not sure if there is anything there that would control these 2, but worth a look.
The blower motor could just have a bad connection. Put it on high and then follow the wiring to it under the dash and give it a wiggle. It may spring to life.
Does the rear defroster still work? I've seen bad LED's in those buttons before, so its not out of the realm of possibities that you have 2 units w/ burnt bulbs.
