Use an air hose if you can, if not, use a can of air duster. I always keep one handy in the car for detailing, or if I need to pull the injectors/LIM i always use it to blow off all the sand/gunk.
sounds like your LIM gasket is leaking
I don't think this idea will work in my situation lol because it is gunked up really bad. That might be 1 of the reasons my car is running like crap.
Thank you all for your replies!
Flip
Did you have issues with gunk pooling up in the holes and around the intake manifold like this?
This was my 99 GTP at 75,000 miles, had a trashed Lower Intake Manifold gasket, due to previous owners lack of maintenance on the coolant. If this is the case, you will want to look between where the head and the LIM meet and see if the gasket is black or aluminum. Some cleaning would be needed, but if it's black and looks like its made of plastic, then its the old style and you will want to replace it regardless.
Pooling in those area's isn't from the LIM gaskets. It's from the sealant on the bolts breaking down over time.
