OK guys, I have a doozy for ya!!!! I have a 1994 GTP, 3.4L engine. This morning while driving to work I turned the left turn signal on and the chime started inside the car (similar chime to when the door is opened with the key in the ignition). I didn't think too much of it until I got to the next intersection and turned right. The chime went off again. Now I was starting to get a bit concerned so I started doing some testing. Here are the results of the tests I could do on the way to work:
-Headlights on. Turn signals do not produce the chime when the turn signals activated.
-Hazard lights do not produce the chime at any time.
-Car stopped and idle. Turn signals do not produce the chime.
The chime only happens when either turn signal is on and the car is above idle AND moving. I even tried to shift the car into drive sitting still and raising the RPM's a bit and the chime would not happen. I got out of the car and checked the turn signal lights and I do have one out on the passenger side. It is the small light on the side of the car. I have had turn signal lights out before and never had a chime come on.
I am at a total loss on this one. Makes no sense to me at all.
Any help would be greatly appreciated.
