Check tire pressure light stays on
Jonarin
My check tire pressure light stays on all the time. I work at dunn tire, so I checked all my pressures, and held the button underneath the dash. It blinks and shuts off, then a second later it comes back on..
If you have a abs light on, I think the tire light will stay on too.
Otherwise just remove the bulb, that system is pointless and was a 97 only thing.
Not pointless. I like mine. Tells me when the tires get low.
But as FFDP said if the ABS lights are on and/or you have a bad hub it will cause this light to come on.
Its weird.. when I turn my car to the on position, my abs light doesnt even come on, but my trac off clicks on as I start driving. Probably a wheel hub, but why would the abs light come on
Tech 2, modis, solous, snap on scanner/matco scanner.
Anything that can read ABS codes and with live data will tell you. If the place you work is more than just a tire shop, you should have something that will read it.
