Cheapest way to a low 13's GTP?
Well I'm in 75 bucks in the subframe a front bumper support for 32 lbs, in like 120 for the ga brakes but that would have been cost on new calipers anyway, and the alum bolts and stuff are all free scratch and dent stuff from work, oh and another good bonus about aluminum, IT DOESEN'T RUST!
ok theres no way the egr weighs 3.5 lbs. its solid cast iron. its at least 10, if not 15. same with onstar box.
Im so glad you asked. Will this list work for you?
Dead Weight(lbs):
___________________________________
lexan/plexi windows 116
***rear window 40
***sunroof 24
***rear glass 17
***rear motors 10
***front glass 14
***front motors 10
catback exhaust 65
bumper supports 60
***rear bumper support 29
***front bumper support 23
***rear styrofoam insert 4.5
***front styrofoam insert 3.5
passenger seat(04+) 52
passenger seat(97-03) 42
spare tire and jack 35
AC system 32
***compressor 9
***duct 8
***condensor 6
***fan motors 6
***other parts 2
***controls 1
door panels(04+) 29
***front door panels 15
***rear door panels 14
race seat 29
weather stripping(04+) 26.5
aluminum cradle 26
rear seat 26
***upper part 17
***lower cushion 9
carbon fiber hood 25
door panels(97-03) 25
***front door panels 13
***rear door panels 12
race battery 26.5
***battery weight savings 25
***battery tray 1.5
heater box 25
carpeting 24
***front 8.5
***rear 8.5
***trunk 7
insulation 23.5
***front 12
***inner firewall 4.5
***rear 4
***trunk 3
wiper system 18.5
***wiper motor/bracket 8
***washer fluid 8
***washer fluid tank/pump 1.5
***wipers 1
sway bars 18
***front 9
***rear 7
***front endlinks/brackets 1
***rear endlinks/brackets 1
headliner 15
airbags 13
***passenger airbag 9
***driver airbag 4
underhood shields/brackets/ect. 12.5
***engine lift brackets/heat shields 5
***cross braces 3
***engine cover 2
***hood braces 1.5
***alternator brace 1
***hood cover 1
dash paneling/covers 12
***glove box 5
***upper dash panel 2
***center panel 1.5
***gauge cover panel 1.5
***lower passenger dash paneling 1
***fusebox covers 1
side skirts 11
seat belts 10.5
***rear 8
***front passenger 2.5
Bonneville coilpack bracket 10
ABS 10
center console 8.5
***console panels/wires 7
***center console cover 1.5
Evap system 5.5
***larger evap canister 3
***hoses/alum tubing/other 2
***smaller evap canister .5
headunit 5
rear mud flaps 5
lower front bumper panel 5
headlight(04+) 4.5
upper motor mount 4.5
floor mats 4
***front 2.5
***rear 1.5
HUD box 4
front mud flaps 3.5
EGR system 3.5
cruise control box 3
fog lights(04V6+) 3
Onstar box 2
air tubes 1.5
rear spoiler 1.5
horn 1.5
front fascia 1
rear view mirror 1
rear fascia 1
rearspkrs/amp 1
rear paneling/speaker cover 1
trunk cover .5
Rotating Mass:
skinnies 42
Grand Am brakes 20
front 15" rims/slicks 10
front 16" rims/slicks 8
lighter torque converter 6
lighter balance shaft 5
Why would you need new pistons if going with nitrous? You wouldn't happen to be a former Foxbody owner would you?
You'll have to add +6 pounds when you install the Dixie horn.
Maybe with the bracket still attached...and the bolts that go into the manifold and the LIM...even then I bet it is close...not that it matters, I'll just remove all the engine pull brackets, the diagonal braces, and the right side done bone/aluminum bracket, alt. bracket and all the other small misc. sh1t and yank 50lbs. off that thing. :)
Well yes why wouldnt you take the bracket off with it... And you have to keep the bolts for block off plates. I too removed all the unnecessary brackets, but i have a thing about removing stuff that makes the frame less rigid. I hear theres an aluminum coil bracket that you can use with the L36 alum dog bone mount, id like to try that.
The L36 Al coil side dog bone mount shatters.
And if that one fails, and you don't replace it, the other side will too.
based on that: I'd recommend at least one iron coil bracket despite the weight.
