Chasing Misfires
DanPrixGTP
Moderator
Recently my car decided to throw some misfires at me. Yes, that's not right, not 1 or 2 misfires, but every cylinder. Idle, car has a very minor miss, WOT car has no misses, but while cruising or under some kind of load (other than WOT), car misses like crazy. According to my aeroforce, the misfires are scattered across all 6 cylinders. Everytime I feel it miss, I see on my wideband leans out to 16.5+.
Now I've thrown a few parts at it to see if anything helps.
- ICM, no change.
- OEM Plug wire, no change.
- New AL104s, no change
- Coil packs tested for continuity and resistance, all checked good.
I'm started to tend to think its injector or fuel related. My next step is to (hopefully) replace the fuel filter. Keep in mind, Im running stock injectors on my setup (in my sig), so I'm thinking my injectors are finally crapping out on me? Odd they all are at the same time though. I'm also going to check the injectors for specified resistance.
Curious if anyone has any ideas before I start throwing more money and parts at it.
I could but it's all in wire loom, I'd have to take it all apart.
I have a couple spare stock injectors in my garage I might try swapping out tonight.
Incase anybody cared at all, which you all probably dont, it ended up being the MAF sensor. She's back together and running like a raped ape again.
Quick question. Did you get any codes at all? Kinda having a similar issue with the imp think its the spark plugs... Hopefully it is
Sent from my LG-D851 using Tapatalk
I'm chasing a random misfire code too cylinder 3 mainly n very lil from cylinder 2 &4
Sent from my SCH-S968C using Tapatalk
