hey guys, first post on here - so, to offer a little back story, I bought a 1997 GP GTP, it was running like cr*p when I bought it...and I got it on the cheap so no worries there. So, I started out replacing a vacuum line and it helped alot, but it was still surging real bad. Found it was sucking air in through the SC manifold gasket and the SC was making noise anyway (play in the unit), so, I managed to find a used on at the pull your part, and installed it along with a new gasket and also replaced the TB gasket, now, when I block air flow it does right out, so, no vacuum leaks. yay! So, the motor is quiet and runs better but it is still missing....so, I get cly 3 misfire codes and I clear them and then I get generic misfire codes the next time the CEL comes back on. I have spark at the coils, wires are good, plugs are good, I have swapped injectors and I turned the motor with the fuel rail out and then injectors are shooting..I have not run a compression test....I am wondering this: is there something common I am missing? Any help would be great....Any more info you need let me know and I can check it and report back
thanks!!
thanks!!
