Eddie Jackson
As I was driving to work this morning, I noticed my Check Engine Light came on. A few moments later, the Low Oil Pressure warning came on the DIC with the Oil Light on the cluster, but turned right back off. A few minutes later, the Low Oil light came on again, but went off as I let off the gas. After checking the code, I found: P0521 (Oil Pressure Sensor) and P0522 (Low Oil Pressure, I believe). The low pressure light has never came back on, but CEL stays on, and came back on after I cleared it (with code P0521). I plan on picking up an oil pressure sensor when I get off to replace after I check the pressure with a manual gauge. Anyone know what the pressure range should be when I check at idle??? Any reason it is only low when I was driving, but went off when I let off the gas??? I was wondering maybe oil pump (knock on wood it's not). Could it let the pressure be low at times then normal at others??? Hoping it's just a sensor, but I'm wondering if it IS a faulty sensor, could it have been low all along, but not told me??? Anyone else had this happen or have anything I might try to troubleshoot if the new sensor doesn't solve it??? Thanks for the help!!!
