CC RR how to
04DetroitLS
Regal GS had one, but the link is dead, anyone know where I can find a write up, I know ZZP had a video @ one time, but i cant seem to find that either.. I fail @ searching lately...
Yella Terra roller directions show a little bit more than that. They say to find Top dead center for each cylinder before you take the old ones off, checking for clearances in new rollers, hand tighten bolts to zero play point, tighten bolts to 25ft lbs which should be between 1/2" to 3/4" of a turn (any more than that would mean you need spacers under aligning plate, less than 1/4 turn would require shortening of the pedestals to increase lifter preload), repeat with top dead center in remaining cylinders in firing order, oil rocerks, bearings, and push- rod adjusters (if equiped) allow time for lifters to bleed down in last cylinder before cranking engine.
...for what? seems like a waste of time since youre clearly not throwing off the geometry of everything that much.
Thanx thats what i was looking for
I know how to swap rockers, I just thought there might be something I was missing w/ these, seemed too easy.... maybe just overthinking again:th_jester:
^^ He is everybody afterall...he better have the answers. I think the TDC stuff is pointless too but meh, whatever.
