Car won't start!!!!!!!!
hawk611
I have a 2001 GTP coupe, and i will not start at times,it cranks and all but will not turn on. IT dose this now and then, hot or cold. i even replaced all 3 coil packs, for the reason that at the time that it did not want to start, i checked for spark from one of the plug wires, and there wasn't any spark. but that was not the problem. I need help, PLEASE. Dose anyone know what it might be?:confused::confused::confused::confused::confused::(:(
or the module...if u have an advance auto near you they can run a free test on the module to see if its bad....for now reptile is correct...if we r both wrong then its a power problem to the module or bad wires to the sensor from the module
Who knows if we're right or not, it just seems like a good place to start and go from there.
Modules don't go bad as often, but they do go bad.
thats why im assuming your right...just thought id give hem all the options in case its good..that way hes not panicking or get pissed if he jumps the gun and replaces it with a new one thinking its the only option and it still doesnt work
