Car won't start
The last two codes are both throttle position related codes with the TPS and the APP (pedal sensor).
That is likely your reason for the no start, you'll have to figure out why they are triggering the code. Look up the codes and make sure they have power, fuses are good etc etc.
Or take it to a shop for a diag.
First code is for oil pressure switch malfunction, last two codes are where your problem is. They are both for pedal position sensor. I assume it's an 04+ car with drive by wire throttle body. First thing I would look at is the sensor connection at the throttle pedal, look for a bad wire and try cleaning connection.
