Car will stall when I turn it on while it's hot
Vlad0691
I have an '04 GT and when it's cold it starts right up strong, but if, let's say, I just drove it somewhere, turned it off for like 10 minutes and then try to turn it back on, it'll crank up and then stall unless I pump the gas a couple times. I think it might be my fuel pump going out? But I'm not sure, it'd be great if someone could give me a little bit more insight.
I've only had the car for less than a year and it has about 125k miles on it, and I'm just now getting into working on it. Thanks in advance! :)
pumping the gas does nothing. Holding it to the floor tho puts it in clear flood mode and leans it out for start up. Run some injector cleaner threw it and see what happens.
I have put injector cleaner through, but it did nothing. And I'm pretty sure.pumping the gas does something,, cause it wont start otherwise.
Maybe I need to clean my throttle body and manifold?
