2005 GTP. Sometimes when the high beams are turned on the headlights go out completely, but when the switch is operated again the low beams answer immediately. And on very rare occasions, the car shuts off completely. When this occurs, nothing works, and all gauges and lights are off. After cycling the ignition to off and back on, the car will start and run fine.
As an additional note: It has been having trouble with the traction control and ABS throwing faults. Not sure how they could be related, but I would like to provide all the information I can.
With the car shutting off completely, it sounds like something is shorting out the BCM, but I'm not sure where to start. I am inclined to 12V electronics, but am not a mechanic, and don't know anything about these cars.
I am wondering if this could be caused by the ignition switch or the multi switch on the column.
Thanks for any support the team can give me.
