Car leaking, not sure from where.
04trbogp
I woke up this morning to fluid on my garage floor. The fluid appears to be minimal but a first. Some of it was fresher then others, and the freshest was a brownish color located mostly near the front right wheel. All pictures taken were from the front right and in the pictures I believe the leak is coming from behind the pulley, any ideas where or what it could be? 04 GP NA
attachment.php
attachment.php
There are 3 things it could be.
The front main seal, the oil pan gasket or the oil pressure switch on the back of the oil filter housing.
I would clean everything the best you can and run the car for a little while, then figure out where the leak is coming from.
Use purple power, simple green or a soap dealio and a pressure washer to get everything super clean. Do it in the street for something to avoid stains on the driveway,
