wakkamis
I was following along on another thread where a vehicle was overheating, did the flush and fill and bleed out the air, and I'm still having issues. The engine started doing what i can only describe as a hiccup. Happens a few times a trip while accelerating or idling or stopped at a light.
I picked up an obd 2 bluetooth reader and the torque app for android and saved these logs out:
Any info would be awesome, Thanks!
(I do not know why its throwing color tags around everything. :/)
Fault log report generated by Torque for Android
Vehicle VIN:
[COLOR=rgba(0, 0, 0, 0.8)]Vehicle Manufacturer:
[COLOR=rgba(0, 0, 0, 0.8)]Vehicle Calibration ID:
[COLOR=rgba(0, 0, 0, 0.8)]Current Fault Log
[COLOR=rgba(0, 0, 0, 0.8)]------------------
[COLOR=rgba(0, 0, 0, 0.8)]P0171: System too Lean (Bank 1)
[COLOR=rgba(0, 0, 0, 0.8)]P0481: Cooling Fan 2 Control Circuit
[COLOR=rgba(0, 0, 0, 0.8)]Pending Fault Log
[COLOR=rgba(0, 0, 0, 0.8)]ECU reports no pending faults
[COLOR=rgba(0, 0, 0, 0.8)]Historic Fault Log
[COLOR=rgba(0, 0, 0, 0.8)]ECU reports no historic faults
[COLOR=rgba(0, 0, 0, 0.8)]Other discovered fault codes
[COLOR=rgba(0, 0, 0, 0.8)](possibly pending, current or manufacturer specific)
[COLOR=rgba(0, 0, 0, 0.8)]----------------------------------------------------
[COLOR=rgba(0, 0, 0, 0.8)]ECU reports no other fault codes logged
[COLOR=rgba(0, 0, 0, 0.8)]End of report.
and
[/COLOR][COLOR=rgba(0, 0, 0, 0.8)]Mode $06 report generated by Torque for Android
[COLOR=rgba(0, 0, 0, 0.8)]================================================
[COLOR=rgba(0, 0, 0, 0.8)]Vehicle VIN:
[COLOR=rgba(0, 0, 0, 0.8)]Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
[COLOR=rgba(0, 0, 0, 0.8)]Test report:
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$01
[COLOR=rgba(0, 0, 0, 0.8)] - Rich to Lean sensor switch time(calculated)
[COLOR=rgba(0, 0, 0, 0.8)]Max: 65,535
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 14,400
[COLOR=rgba(0, 0, 0, 0.8)]PASS
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$02
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,999[
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$03
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 9,583
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$04
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 17,638
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$05
[COLOR=rgba(0, 0, 0, 0.8)]Max: 10,880
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 1,792
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$06
[COLOR=rgba(0, 0, 0, 0.8)]Max: 10,240
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 896
[COLOR=rgba(0, 0, 0, 0.8)]----[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$07
[COLOR=rgba(0, 0, 0, 0.8)]Min: 42
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 230
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$08
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 231
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0a
[COLOR=rgba(0, 0, 0, 0.8)]Test incomplete or dependant test failed
[COLOR=rgba(0, 0, 0, 0.8)]--[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0b[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)] - Rich to Lean sensor switch time(calculated)[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Min: 21,944[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,694[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]FAIL[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0c[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 9,305[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 13,888[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0d[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 32,903 Min: 32,738[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,782[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]PASS[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$07 CID:$4f[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)] - Minimum sensor Voltage for test cycle(calculated)[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 33,564[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 31,023[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$01[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)] - Sensor period(calculated)[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 150[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 16[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$04[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Min: 50[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 50[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$05[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 289[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 53[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$06[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 123[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 31[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$07[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Min: 600[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 600[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$42[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Min: 6,000[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 6,039[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$48[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 32,868[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,770[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0c CID:$60[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)] - Misfire counts for last/current driving cycles(calculated)[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 32,768[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,768[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$0e CID:$12[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)] - [/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 0[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 418[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$01[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 65,535[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 14,400[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$02[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,999[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$03[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 9,583[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$04[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 17,638[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$05[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 10,880[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 1,792[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$06[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Max: 10,240[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 896[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$07[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Min: 42[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 230[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$08[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test result value: 231[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0a[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]Test incomplete or dependant test failed[/COLOR]
[COLOR=rgba(0, 0, 0, 0.8)]End of report.[/COLOR]
Vehicle VIN:
and
