Car heat-seized
xDonny
Hello fellow GP enthusiasts
I was driving home the other day and my rad hose popped off the top of the radiator, pissed coolant everywhere, I didn't notice until my car started making a ticking noise and shut off completely about 1/2 KM later.
I opened the hood to billowing white smoke and the smell of burning coolant, after realizing what happend I had an "oh ****" moment
So, what I have done:
Change oil right away
new coolant
replace rad hose and clamp
replace #6 and #3 spark plugs (Were throwing a mis-fire code)
Before I replaced those spark plugs the engine was shaking really violently at idle but smoothed out with any throttle. It has since smoothed out to a reasonable level and isn't throwing any misfire codes (yet) and I was wondering if there is anything else I should check?
Thanks,
Donny
So it's still running funny or what are you asking now?
You might need new wires if it still runs sorta rough, that would be a cheaper solution and clean and check the coil packs.
It seems to be idling funny still yeah, it's smoother that I changed the plugs but doens't seem to be back to 100%
Well just drove a couple miles to pickup my sister at work and seems rough again... Just realized 3 and 6 share a coil pack so that's what I'm gonna check when I get home
Another update:
Wasn't the plugs, wires or coil packs.. Thinking of renting a compression tester to see if it's a chipped piston or something, the plug wasn't mangled so I'm hesitant about that.
I was also thinking it could be a rocker or a bent rod?
Any thoughts on the matter gurus?
The PO could have chipped it and replaced the damaged plug. If you can get a borescope to check that would be good
Edit: saw your gonna do a compression test.
Sent from the Milky Way
Let's level set here. NA usually doesn't chip a piston Overheating badly can crack a head/kill a head gasket. Still..it does take a lot.
Saying it's running bad is tough to diagnose. Could you post a video?
Had no idea it was N/A he never specified.
I also...have overlooked which section it is in many many times. It's mainly because I read all new posts all the time. Totally understand, when he didn't specify either.. I don't assume either.
Im thinking a bad head gasket. Sounds almost like mine when mine went out. Go get a block tester from autozone and test to see if you are getting exhaust fumes through your radiator. If the liquid turns a different color, it means you are.
