JakeLasVegas
Hello again everybody. Long time no post.
I had a slight water leak from the corner of the lower intake manifold on my 97 Grand Prix 3800 with 156K miles, and had the manifold gasket replaced and also installed a new upper intake manifold and gasket set. This fixed the water problem, but about a week later noticed a cloud of white smoke coming from the exhaust pipe upon starting the car for the first time of the day. The smoke quickly dissipates and doesn't smoke after the engine is running. It only smokes on about 1 out of 10 starts.
My question is: Could this be caused by something involving the manifold gasket change or is it a coincidence? I am thinking that with the smoke occurring only on start-up, could it be the valve stem seals? If it is the seals, can they be replaced without removing the heads?
Will appreciate any and all thoughts on this matter. Thank you.
