Well I finally got my car back together and running. Took the car out for a test drive and noticed I have a weird miss. When the car is in lower rpm's you can feel it more, especially in overdrive. It seems to buck in overdrive when going up hill.
So I replaced the plugs, wires, coil packs, cleaned the MAF, checked for vacuum leaks, replaced the fuel filter and t still has a miss. I don't notice it when I'm on the gas so to speak.
When I pulled the plugs #4 spark plug was black all the rest looked normal. Seems like the miss doesn't change idling when I pull the number 4 spark plug wire.
So.... Thoughts? I was going to swap around injectors and see if I notice a difference.
