thegipper
For the last couple months I've been having to put some coolant into the reservoir every few weeks. Not much but maybe a half quart. I don't see any on the ground anywhere but it has been wet/snowy because its winter. Lim gasket have been replaced with an aluminum one (a year ago) and UIM and elbows all were replaced. Oil is fine, isn't burning it.
Places that I have checked.
Coolant elbows (upper and lower)
Passage way between LIM/gasket area (not sure if thats what its called but the thing under the TB
around the water pump (cant see that well even with a mirror)
Reservoir tank
Reservoir tank hose
Radiator area and upper/lower hoses
Now I did find coolant all over the power steering pump when I was looking from underneath the car. See picture : http://i1127.photobucket.com/albums/l640/thegipper1/Screenshots_2013-02-23-14-13-01_zps6b394c1f.png
I cannot figure out where the coolant is coming from though. Someone said maybe the weep hole on the water pump. No clue where that is. Again, can't see that good even with mirror by the water pump.
Anyone know where this coolant is coming from?
Reservoir tank
Reservoir tank hose
