Can't get timing to match table values!??!
DanGTP
I'm working on an '05 NA Grand Prix. We've been having problems with low throttle KR and I have started removing timing to get rid of it, but with only a little luck.
I've set both the high and low octane tables to 10*, but I see as much as 30* when scanning. I did find a "Max Torque Timing" table, but HPT recommends not to mess with it. Would that be advancing my timing above what the main spark table tells it to? Here's a screenshot of the timing from our last scan. Everything above 1000RPM should be 10*.
If you're using Hptuners, in the 97-03's there is a timing add vs fuel mixture table, and it added 7*+ at some AFR's, there may be something similar in the 04'+s
