Can I use a ZZP LIM Thats ported for a IC without the IC????
thatgtpguy
I Found a sweet deal on A ZZP LIM for my GTP but its machined for a IC and I don't want to run a intercooler. CanI use it on a NON IC set up
Post a picture of what you got. Why run a intercooler manifold without a intercooler? It's not ported.
That's not a ZZP manifold.
No groove.
2 holes are not plugged.
Some one has cut the opening bigger for an intercooler.
Why install this if no intercooler?
that looks like the zzp first version before they did the pcv grove look closer at the coolant ports they are plugged but then again I thought zzp plugged them with something other then red threading plugs
The air flows out the triangle at the other end, it's not going to change it's mind and move the other way. Air, like most things in physics, is lazy.
