cam problems
boredout
ok in january 08 my 2002 grand prix se blew a head gasket so in feb wen i got my irs refund i spent close to 2500 an just went ahead an rebuit the whole engine i didnt even make it through the break in period an spun a rod bearing it ate up the crank so bad it couldnt be turned an sent shavings through the whole engine an seized up a lifter causing it to take chunk out of a cam lobe
Did you have a question? If you do and it's engine related try posting it up in the tech lounge. You may get more responses that way.
an the piston that spun the bearing also messed up the cylinder wall so now i got a new crank,bearings,oversized pistons,timing set,lifters,stock cam is on the way an the block is bored 30 over,heads shaved,valves,springs,retainers. But i would really like a perf cam but cant find one any where for my 3.1 any feedback would b appreciated also some 3.1 headers?
Try posting your questions here- http://www.grandprixforums.net/f15/ this is a section dedicated just for you 3.1 guys. In my opinion you would have better luck getting answers out of the tech lounge though. Good luck! Also stop by the ''introductions section and introduce your self to all of us.
