cam help
VS cam is for a blower car. look as ZZPs GT1 cam.
also, if you go cammed, youre going to spend more money than you need to in order to get a small amount of power that you want.
ok so some er's is the way i should go then jhow much more gain from cam, also if i go er, should i get valve springs retainers etc and pushrods
with an n/a setup youd be lucky to see 10-15 more hp from a cam in comparison to a set of rockers.
