I have a 2008 GP and few weeks ago when I turn off my car the headlight still remained on. I tried turning it off from the switch but that didn't work. Put the key back in the ignition and toggled it to the ACC and off position and after few times it turned off. Just today it happened again, did the same solution but didn't work. I locked and unlocked the door with the FOB and it eventually turned off. Can it be a fuse issue? I read somewhere that someone replaced the HDM low beam relay that is in slot #35 and that worked. Any ideas will be much appreciated.
Sent from my SM-G935W8 using Tapatalk
