Iron Indian
Anyone who has done rear brakes should be able to answer this easily. This is for the REAR brakes btw. Ok as you know there are two pins for each caliper. One had a tip on it for a bushing, the other does not. Ok, is the a certain order they should go on either side? The pin w/ the bushing top or the bottom hole? Or does it not matter at all? And can anyone confirm this? I want to make sure my dumbass didn't mix them up somehow when doing my brakes.
I plan on messing with it hopefully this weekend. I haven't touched it since last weekend. I want to get a list gathered so i can make to check every little detail and not miss anything.
Thanks...
Thanks...
