Cable mod
BoostedPontiac
Regal GS Level Member
First off let me say, THIS IS NOT MINE, im just importing it from grandprix.net because i didnt find it here.
Credit to:
ordonez1307
ok, i got some pics from someone else, but this is the process.
Materials-
6 feet of 3/16 wire cable. $.38 a foot at Home Depot
A pack of 3/16 wire cable. Like $2? at Home Depot
Jack
Jackstand
Tire Iron
Jack the rear of the car up, remove wheel
In front of you is the spring/strut
Drill 4 holes into the car. Circled in the pic.
Feed the cable from behind the frame and up through the holes in the strut.
Cross the cables through the clamp.
Use an 11 socket and tighten the clamps down very tight.
Replace wheel.
Take off jack.
And yes i know its shady but hey its worth a shot. ONLY FOR RACING USE. This will rattle your teeth out and possibly cause suspension damage.
What was the point of this? I forget. Something with the track where it keeps the rear end from squatting too much, right?
It basically keeps the rear suspension from moving down. that equals loose fillings (and if you don't have fillings, you'll need them after driving your car like this)
