bushings in rear main seal cover
usually i just bolt the oil pan on sans gasket and toss two rear cover bolts in just finger snug so the pan holds the pan gasket rails in alignment as you tighten the rear cover slowly and gently as it compresses the paper gasket while tightening in stages with relaxation time in between
It's not glue. It's a plastic sleeve. I felt it was there to help position the cover better than bolts alone for the rear main.
