Building new FE3's, mount question
SaukRapids
I can't car too good.
GM's parts diagrams show a wedge shape spacer in with the mount, like #4 on this -
3o85OKnR_j4MDQN7Unl-KWI4-Q6RwxST3ufgVKujhEe0snjrP0cIkTLzA11tSnEJOoK8Of6EXE-qZoo1NgxY-tfhtz9QHP9laisX8rzp25WkhKpdGYUbLkuCNY74m35ixD2cFQk60MW_8fM0TVqfgCWIRlTHzDYJ_JedErEKAt3SodSy2GRE18OwoxBMXve0htQPGXgup0R8JmaepgYPeKa0Njb7t4pmXP9pArDNBKcBYUB2sWyU53oShXfhKsMM8Vu_6ex53aRZ_2LsSu7gSCTTC708MHGQGccDgspEl0Vy_JKNxqBhI8cTrWXJRbTNCgPZBDtP_YJYq4R97bVFcDaYEIgEovA6iX1CAv2vNFb2Eo5JTbChE5KWR36rJfkPS2F_n58vjWUkGJ8ityAt0H1VtctSMq5VbgIRqQry5EFAaHDWRCRevdBiGeMWI3Q1e4yb43_uuNoiVxeMMFU5dGYVgl5A63ePeuay_DSaFxNEOe_F1iq79aaQax49U-kF5BNYSrP5VC_wx3j1_vGXvgFx4H7upMA87QLNu0zdnNeS69eauwUIG26vJTcFNRj9sfXPcFUW_TY7yw5GEHvTI4bZu2lOwzEZHQpa6UvYgqFMEiWt0_VLkdTNj4KEUMkqQDnJ_5tr8ZGsY0PbZRimuj5aIHV79DtUU-CMxRrZ4ZMp6Lu3lBXrLWFKS_WY6WE_ehm3cKaKEMzYtLqXxAAlQm_o=w634-h519-no
Will I need to buy that wedge thing, GM 22167000, or will it be in with the mounts depending what I buy? These look slightly different shape than those pictured in Rockauto's mount kits.
They're only about $8/ea so it's an easy order if I need em. Thanks for any input!
I just went ahead and bought these off ebay. I don't know if they're getting scarce. Well, I'm not even sure I'll need them for that matter.
There was also a couple "Shield" items I wasn't too sure about. I found the OE bellows, so I may need them.
It seems like it should be very straightforward, but it just isn't that simple finding the parts to piece these together.
I plan on making a list of the required AC Delco part numbers for this project. Might even do a write-up, amount of free time pending.
Part #'s so far:
Strut - GM 506273
Dust Shield(?) - GM 22189840
Wedge/Isolator - GM 22167000
Bellows - GM 901083
You wont need the angle spacer if you get Monroe mounts. I had bad luck with groaning using those.
I would buy the AC Delco professionals and re-use the plastic spacer.
It looks like most mount kits manufacturers think you will re-use the old spacer.
It does get pricey if you are replacing 100,000 original isolators, etc.
Make sure you add more grease to the bearings i
Anyway here is a pic I found of a Monroe assembly.
That pic will be useful later, and I actually didn't think of grease yet either. Thanks on both accounts.
Think I'm gonna pull one side, take the spring off and see what's layin there. Then I can compare with what I plan to order and ask questions.
Just wanna make sure it's all here. :th_beer-toast1:
I checked my Rockauto order from when I did it a few years ago.
This is all I needed to get it done,front and back.
The Monroe strut mate kits are probably your best deal. I didn't grease mine before install.
I learned a lesson. I replaced them with Duralast from Autozone just because I decided to remedy it one day. Those I greased.
Ok, I have most the parts on their way here. spazz, you mentioned grease. I gather the bearing needs it, but did you grease any other areas?
Read maybe do the insulators too? Asking cus a friend just did them and has an awful noise when turning the strut by hand.
Thanks again!
