streetsmart
hey there everyone. i have an 04 Comp G and i noticed a big amount of brown sludge under the radiator cap AND in the resevoir. any idea of what could be causing this? i guess i need to flush it?
thanks!
thanks!
Sounds like your intake gasket allowing oil into your coolant. and coolant into your oil. An ethylene glycol test to your engine oil will confirm coolant contamination.
Good news is, its a super easy job and now Fel-Pro FINALLY made theyre famous upgraded intake manifold gaskets (permatorque) for the 3800. been using those gaskets on the 3.1 and 3.4 for years and its a permanent fix that doesent break down like the replacement plastic gaskets do.
It is dex cool. Period. Not oil.
Do not flush it yourself get it flushed by a pro with the machine (midas for instance). You should go back a month later to get it flushed again to get all of the circulating jelly out
