Broken rocker arm bolt
Wsmccoy
So as the title says I have a broke rocker arm bolt. I put on 105 lb valve springs a week ago and while driving home from work I heard a ticking noise, I know I should of pulled over and inspected it or got it towed home, but when I was a couple blocks from home it got louder and the check engine light came on. I scanned as I was pulling in the driveway and had a misfire code for cylinder 3. Took the valve cover off and found the bolt broke.
I know it's hard to tell with the pedestal still on but I can tell it's flush with the head. So what are the chances that an extractor could get it out? And just to add I replaced the bolts and torqued everything down just as I did when I installed the 1.9 modified rockers months ago. Is there a possible chance it was a weak bolt? All other bolts are still torqued correctly and not loose.
I went through the same issues ... We tried extractor, we even tried welding a nut to the broken stud to back it out... Ended up having to drill it out.
I already new it is going to be a pain, well I guess I'll know what I'll be doing this weekend instead of tuning for the 60lb injectors I have laying in the garage. And I thought I ordered comp cam bolts but when they arrived it was oem bolts. I thought they would be fine. I already placed an order for comp cam bolts though
Your not going to want to hear this but you will prolly be best off if you take the head off the car.
That's what I was wanting to avoid. I'm going to go ahead and try with it on and see what happens. Worst case I'll take it off
Go buy a left hand drill bit. Heat the head around the bolt (not the bolt)
You might get lucky and it'll back out.
If not then buy a masonry drill and have fun. The masonry drill has a high speed carbide tip that will drill case hardened steel. It will drill through that bolt with no issues.
Sent from Not so smart smartphone
If there isn't loctite on the threads and the bolt isn't bottomed out in the hole you should be able to back it out. I use a vibrating engraving pencil to spin broken bolts out. Left hand drills work good to.
I used grade 8 socket head cap screws.
