    TIPS:
*BRAND NEW* SLP Front Sway bar + Energy Suspension Poly Bushings PRICE CHANGE
SomeDudeAtHome
So long story short, I bought the SLP bars and the rear got lost in shipping. I got impatient and bought new bars instead of waiting for just the front to arrive and now have it just sitting here.
Bar is brand new and comes with brand new Energy Suspension poly bushings. This bar will stiffen up your ride a TON. Plus you get the bonus of not having to spend nearly $400 at 3800performance to get the front and rear while the front is the only one worth getting. I say that because the rear is small and there's better bars out there. My loss is your gain. Located in Buffalo, N.Y. $170 shipped FIRM. Price is more than fair since it's brand new, comes with bushings, and shipping will be a lot. The bar is heavy and will need a big box.
It's hard to make out in the 3rd pic but you can see the dimensions on the bushing on it to know for sure it's 35mm.
Re: *BRAND NEW* SLP Front Sway bar + Energy Suspension Poly Bushings
I believe you will need the LCA from a 97-03 car because of the way the end links match up. Should probably get an 04+ guy to confirm that though. Would be a perfect time to replace your old LCAs with this bar though!
I've got an 05, and I can confirm you need the older style control arms. This only applies to 04-05 though, 06+ reverted back to the old style, probably because (from experience) bolting the end links to the control arms helps with excessive torque steer.
Dorman control arms are cheap and well made, it's a worthwhile upgrade for sure. I'd just advise to pick up a bigger rear bar if you upgrade the front one.
Thanks for the confirmation didn't know that about the 06+.
Is this bar supposed to be better than the GMPP sway bar?
Is the bar solid or hollow?
ya it's a millimeter or 2 bigger and is solid vs the gmpp being hollow.
hey 04+ guys i just want to let ya know that it will not work with 04+ unless you get the older style sway bars. people have already dont that and im actually in the process of doing that now
