Steven Monteith
My brakes have been screeching pretty bad lately and it seems its just getting worse. I have new calipers, rotors, pads, hardware. What could be causing this screeching??
I used stock aftermarket stuff from a local auto parts store. Yes I lubed everything and gooped the pads.
Some brands that I've never heard of.
Good pick.
im guessing you have a grand prix...i had the same problem about a month ago...take the wheel off and in between the hub assembly and the steering knuckle there is a metal bracket that is easily bent. It holds the abs wires in place and also makes it so that the hub will come out if you need to remove it. But make sure that that piece of metal in between them is not bent and touching the rotors. Especially on the part of it thats at the bottom side of the rotor as it only has a few millimeters between it and the rotor to begin with
