jprovinsal
any brake recommendations?
i know nothing about brakes but i want to improve my car... what should i look at getting?
Drilled and slotted rotors. And some decent pads. I usually find the cheapest slotted and drilled rotors and go with those (ebay)
Or if you wanted to go all out you could get the F-body brakes and calipers. You would have to drill and tap the caliper bracket out to a larger size though. But then you would have 12'' brakes.
if i could do it all again i would just get the 12 inch caliper brackets. i switched to the Fbody and have had nothing but problems with the ZZP stainless lines
x2. The 12" Impala/Monte upgrade is a noticeable improvement, and is probably the cheapest/easiest upgrade out there.You can also get the caliper brackets from an 00-05 implala/monte carlo. This allows you to use the stock caliper and a larger rotor in the front.
I ended up getting the 12" caliper brackets and got a set of blank rotors from r1 concepts. I will be using hawk pads with them as well. I had slotted rotors and they are more for looks.
