04gpking85
So I got the warning that says "brake fluid low" so I was wondering, does that mean that the brakes are going bad or I just need to put in new fluid? 04 GP GT2, don't know the last time it was changed, if at all.
Usually the fluid only gets low because the pads are getting thin, and the calipers are pushed pretty far out. I love it how people keep the master cylinder full, and when they compress the pistons, its like Ole' Faithful!!
That should have no ill effect on level since it is a minuet level. Not even close to causing a light
Could also just be a faulty sensor.
Well it turns out the rear brake pads were worn beyond the sensor and that's why it was doing that
