moddman
Donating Users
I been dealing with this Brake Chattering/Clicking for a while and finally nailed it. It was coming from my drivers side wheel definitely from the brakes. It sounds like a symmetrical clicking sound happening at the same point when wheel is turning. Well, it was the brake rubber bushings & steel shim hardware that needed changing that solved the issue.(Part Number:H5632Q-Front)(Oreillys)
Note:The long thin cylindrical bushings are not needed. Those are only for front aftermarket bolts(non-dealer).
The other issue I was having is on the passenger side my caliper was not releasing the rotor and it turned out to be the small bushing on one of the caliper bolts which swelled from anti-seize that was put on there by a shop when they did my trans. (This was causing a reaction that felt like a shudder like a PCS/Valve Body problem,so check your brakes, first.)Well, I couldn't find that small bushing anywhere for the life of me. Though what I figured out is the rear bushing kit has that small bushing in there that also fit on the factory front bolts.(Part Number:H5626Q-Rear)(Oreillys)
Note:To avoid swelling of the bushing use only silicone based brake lube(Sil-Glyde). It remains wet even with Hi-Temps.Sil-Glyde® Brake Lubricant(Oreillys)
PRODUCT #
BK-1, BK-1D, BK-3, BK-4, BK-8, BK-12
DESCRIPTION
Sil-Glyde Brake Lubricant
PRODUCT #
DESCRIPTION
