How do you guys bleed your brakes?
I have a '98GTP with the Bosch 5.3 ABS modulator (124k miles). Lately, I've been struggling with weak brakes.
By "weak" I mean that they feel mushy (like there is air in the system).
Long story short: I've replaced the master cylinder, pads and switched to SS flex lines. They're much firmer now.
The question I have....
I've read mixed things about the Bosch ABS system. Do you need to "home" the cylinders before bleeding or not? Some articles say the pistons must be toggled then bled, some say that the system has its own reservoir and is closed to the rest of the system so long as the ABS is not activated.
What I did was bench bleed the master cylinder and then use a pressure bleeder and then just bleed per normal (PR,DR,PF,DF).
How do you guys handle bleeding the ABS system?
