GeePeeOhTiger
Hello all, long time no posts. Have family heirloom 2002 SE with sentimental value (long story) whose front-to rear brake and especially fuel lines were absolutely ROTTED to death and starting to leak, IMMEDIATELY after I FINALLY had gotten around to dealing with the LIM gasket, argh. Had to hack the lines up in SEVERAL pieces underneath to get them out, even AFTER unbolting all the brackets (ALL of the "quick-connect" fittings were a multi-week horror show just to undo). Got brake lines back in (sort of), RR fits perfectly but LR line isn't really in right. Even though I had purchased the correct a factory GM fuel feed (only) line a while ago, I ended up buying the so-called "easy-to-install" 2-piece FL254A 3-line kit (feed, return & vapor) from FineLines. Can't even come CLOSE to getting the front halves (which are roughly half hard prebent line and half flexible stainless reinforced hose) routed up into the engine bay correctly. Thinking about trying flexible stainless hose from the front end of the rear halves of the lines (same thread as outlet of filter) to the quick connect fitting in engine bay. I see AN adapters available everywhere but can't seem to find what I need. Out of pure desperation, I'm actually considering high-pressure (>100psi) EFI hose and clamping it as securely as possible but obviously concerned about a fireball. Any ideas? Thanks in advance.
