Bought zz p bin file now...
GTP4
Like my thread states.
I bought a zz p bin file and now my car is throwing a p133 code.
Autozone says it has to do with the front 02 sensor, or runing too lean.
I will say it got rid of my kr problem.
Yup running on the 3.2 kr free.
Anybody had this problem before?
My rear 02 is disabled.
If you bought the bin from ZZP, go back to them. They setup the tune and they are the best ones to be able to tell you what is going on. Everyone tunes differently, so your best bet is to talk to them.
^^^^^^^^ that is a good idea!
how many miles are on the car? I change my 02 sensors every 20thou mile...
i have the same sensor... get the same code. my fuel trimes are high too, i think thats why it threw the code. if your ltft stay in the positive too long i throws the code. when ltft's are in the positive it means the o2's are saying its lean, so its richening it. i dunno. i got the code after i put my pacesetters on (replaced o2 at the same time) and it comes and goes. checked for any possible exhaust leaks but cant find any. did the code come from just replacing the pcm? nothing else?
Yeah, it threw it after the bin install.
But the code calls for slow switching 02 sensor.
Maybe the sensor is taking to long to read or its slower on reading.
It could be 3 things. You MAF table is so low (not enough fuel) that it is not even reading anything on the nb because it is so lean (happend to me) Or you have a bad o2.Or you have melted wires going to the o2 sensor That is the only three things that can cause that code to apear.
